Cylinders... which brand is best?
I
I
integraoligist
9 months ago when i was all set to get the entire air kit, i was GOING to get the CCE cans from Gauge... I can finally order all my shit and now Gauge has switched to FBI.
So now my question is, what brand Cylinders should I go with?
CCE, FBI, EAI, RailIt Customs, MIC, ShowTime, DNA?
So many diffrent one's i have no idea which to get now.Thanks all!J
Sickcivic
go for mic's man there smc cans i ive had them for over a year now and they ride great and have never had 1 problem with them and they have a camber built into them there great man thats what id go with. just stay away from eai they are crap i keep tellin people to go with smc but they never listen trust me man there dope
I
integraoligist
MIC are SMC brand? I know SMC are the best of the best...
MIC has diffrent versions of Cyl's... are both the 145psi versions and 300psi versions SMC?
This is going on an Acura so the 145psi's should be the right size, correct?
Thanks man!
btw, before anyone start telling me to get AirStruts, I can't because I can not "mod" them... my body sits much lower then stock already so I have to modify the Cans/Struts so when at 0psi i'm not smashing into the ground.
(unless there is some way to mod the struts now?)
Thanks again all!
phatmx6's avatar
phatmx6
yup smcs from MIC no questions,,its the only can i will run,,,they have the 180 psi and the 300 psi,,i run 200 to the 18s all the time ,,never had a problem at all,,ask for adam,,,, www.illicitcustoms.com" target="_blank" rel="nofollow">www.illicitcustoms.com dude is right about eai,,those are parkers but they are ass,,pos,,,dna cheap version of the aim can,,,cce is a smc copy that they make not near as good o rings inside but they have the big shaft,look identical,,,but diff o rigs,,showtimes uses the aim cans,,i dont know what rail it uses aint seen them or fbi,,i dont mess with them chek me out if ya have any questions,,www.illicitcustoms.com" target="_blank" rel="nofollow">www.illicitcustoms.com
TwistedPhil's avatar
TwistedPhil
The FBI cans are from DNA. We've sold them for about a year, and not really any problems... but we don't sell a whole lot of them either. I'd guess that we've sold around 2-300 cans in the past year, and had less than 10 come back with problems- not too bad, but I'm not saying they're all that and a bag of animal crackers either...
-Phil at FBI
Sickcivic
yeah man im runnin 4in in the front and 3inch in the back i run 180 psi all the time and it has never had one problem.ill tell u how shitty eai is. one of my boyz just put some eai cans on his civic and BRAND NEW when he lifts the back up all the way it leaks all the way back down out the bottom of the clyinder, i tried to tell him but no no ill go the cheaper route well u see what that got him but thats just what i think. so wherever u can get smcs get em i wouldnt go with anything else
I
integraoligist
Seeing as though all you guys and running 180-200 psi, i assume you go with the 300psi one's with 4"bore, 4" Stroke, via this link: http://www.masterimagecustoms.com/store/4x300.html
And should I go ahead and get a "rebuild" kit for it or no?
Thanks again all!
sweeden's avatar
sweeden
SMC no other way to go
Sickcivic
i orderd my kit straight from mic dude 3/8 fast valve and 1/2" air line and its on there site under civics they gave me the 145 psi cans which have no problem takin 180 obviously haha but im about to lay mine out so ima slow it down some back to 140 to 160 mic gave me a pressure switch that cuts on at 160 and goes off at 180 in the kit so thats tellin ya something but mic is a good way to go they want shit u
Sickcivic
oh and about the rebuild kit i woudnt even worry if u get smc there is no need in my opnion but if u go another way u better order u one
s10
last post by baha +1y
